Fri, Feb 7, 11:24 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: Help ! Main Window Problem
poserpro ( ) posted Thu, 15 March 2001 at 11:11 AM ยท edited Fri, 07 February 2025 at 8:41 AM
I opened PPP today and found the Main Window slided to the upper left og GUI just under the menu, as the text is hide by the menu, I couldn't move it back to the center. And the Light Contol and Camera Control are behide it so I couldn't us them too. TIA.
PhilC ( ) posted Thu, 15 March 2001 at 12:10 PM
  • Go to Edit/Preferences and select the two Factory State options.
  • Click OK and re-start Poser.
  • Next arrange your interface and document window to your liking.
  • Return to Edit Preferences and this time select Preferred and Previous. Click on the Set Preferred State button then the OK.
Now whilst we are at it, find the UI memory dots and click on one that is not being used. This will remember your current GUI settings and can be used to quickly return to them. I often use this after opening a PZ3 created by someone else with different settings.
poserpro ( ) posted Thu, 15 March 2001 at 2:40 PM
It works now thanks. It happens when we change the resolution of screen, the main window will be missing, gone, nada, I don't know if ppp behaves this but I won't try it. I always tells my students not to change resolution when Poser is opened. Cheers
