Mon, Nov 25, 2:51 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Poser Pro Pack 3DS Max Plugin-Textures figures of unvalid vertices.
genetic ( ) posted Thu, 15 March 2001 at 12:42 PM · edited Mon, 25 November 2024 at 11:55 AM
I wonder if anyone has a fix for this problem. I'm encountering a problem where i have several poser models hosted in a 3DS Max Scene. The first 5 Models render works fine, but about the 7th to 16th model come up as has an invalid texture vertices the render could not continue. Any suggestion on a way around this problem. I haven't seen anything on Curious' site. So I was hopeing someone on here had a similar problem and has a fix for it.
chromecafe ( ) posted Thu, 15 March 2001 at 4:43 PM
Yeah I Have This problem also curious are aware of it but no solution yet I should think it will be adressed in the patch
