"Does it exist and where can I find it?"
Appendix B of the P6 gives some basic information about the file structure.
There is (or was) a site that listed the meanings of the "GetStringRes" values, but I've not seen an attempt to list the keywords used.
Your best bet would be to mine the executable for strings (Dodger mentioned this once if you can locate the thread).
One attempt at parser is -> ThePoserParser v0.1
Dodger posted some scripts at RFI that might be of use -> http://rfi.elgeneralisimo.com/forums/index.php/topic,57.0.html
There's a decision you have to make when writing a parser for Poser files, which is whether to include all the keywords and their substructure, or leave a more detailed interpretation to something else.
My own attempts at parsing Poser files have concentrated on the latter.
IMHO it's a pity EF didn't introduce an XML based format.
Attached Link: http://www.kuroyumes-developmentzone.com/poser/poserfilespec/ucr2filespec.html
You could also try kuroyume's 'unofficial CR2 specification' at the link.Steve
Also, don't forget this link... ;)C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Oops - cross-post!
off.
-- Bjarne
Stroustrup
Attached Link: http://www.rbtwhiz.com/
This is the site nruddock was referring to for "GetStringRes".
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
Secrets of Figure Creation with Poser 7, the second edition of SOFCWP5, will be coming out hopefully near the end of this year, as well. Just a note: Dodger has been working on a Perl module to parse Poser (PML) files into data structures, including manipulation methods. It's not done yet, but he has had some fair success, including the ability to translate a standard Poser file (no readScripts) into XML (though it should be noted that Michael 3.xml is friggin HUGE) One of the problems with having it parse intelligently is that PML (Poser Markup Language) is really inconsistent in its structure. The weld and addChild directives are strong examples of this, as is the format of ERC code and the sphereMatZones directive: both of the latter should be delineated a block for consistency, but aren't. It should also be noted that severap programmers have done this already, including Ajax. EasyPose Underground very clearly parses Poser files into its internal data structure and writes them back out. Also, finally, if you get vim (www.vim.org) and Dodger's Poser syntax highlighting plugin for vim, you'll find that the latter contains most of the information you want in a very basic and non-verbose format, and that could be of some help. It needs an update or two that he will do someday when he gets a round tuit, but it's pretty comprehensive and includes things that aren't usually seen in most PML files. This plugin file won't tell you what things do, but it will tell you what they are (though you'll have to work out a bit of basic vim script to make sense of it)
I'm the asshole. You wanna be a shit? You gotta go through ME.
Oh, and it should also be noted: Dodger has successfully completed a basic Wavefront Object module for Perl which allows scaling, translation, and rotation in Perl code. It doesn't deal with splines and stuff - mostly only Poser-compatible OBJs, but still. http://cpan.uwinnipeg.ca/dist/Model3D-WavefrontObject
Does it exist and where can I find it? Thanks -WTB
