Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
Take your Michael textures and redo to fit your P4 templates. Of course, you should check the readmes for any of the 'bought' textures (well, the others too) to see if there is any problem with doing this. Use a 2D graphics program with layers (PSP, PHotopaint, PS) and put the template for the model on the bottom--then grab and fit various parts to areas on the template and eventually you will reach a stage where you can smudge and soften the overlapping areas. Some people are just better than others at doing this, but with some patience, you should be able to get something you will like and be able to use for yourself.
Hi. Can you use michael skins in poser? on poser people? if so... how? :) cheers -Kieren
