Fri, Feb 7, 12:49 AM CST
Subject: rotate while rendered
disjointed ( ) posted Mon, 02 January 2006 at 5:55 PM · edited Fri, 08 November 2024 at 8:37 AM
Hi all, im wondering if there is a mod/method that will allow me render an object and then rotate around it freehand while its still rendered, much like how one would rotate around the object in wire frame.
Many thanks
Nino
Message edited on: 01/02/2006 17:56
RodsArt ( ) posted Mon, 02 January 2006 at 6:51 PM
The closest you can get to a modeled rotation if I understand you correctly is to switch to Open GL, rather then Wireframe. This will give you a better 3D visual in a solid representation. Otherwise you would have to do an animation, then play it back.
___
Ockham's razor- It's that simple
RodsArt ( ) posted Mon, 02 January 2006 at 6:55 PM
___
RodsArt ( ) posted Mon, 02 January 2006 at 6:58 PM
This veiw however will not give you a true REP if your model has boolean operations applied and will not show the texture if any are applied. Like I said, the only other option is animation.
___
drawbridgep ( ) posted Mon, 02 January 2006 at 7:27 PM
Bryce 5.5 does have OpenGL rendering with textures. Pretty slow and a CPU cruncher, but worth a try.
Phillip Drawbridge
Website
Facebook
scoleman123 ( ) posted Tue, 03 January 2006 at 10:04 AM
what else needs to be installed. at my computer at school, i cant seem to bring up the choice of OpenGL or any other.
 facebook.com/scoleman123
TobinLam ( ) posted Mon, 09 January 2006 at 9:12 AM
Isn't OpenGL partly a hardware thing? I don't recall ever installing OpenGL.
