Well... First point is that ALL computer images, in this contexts therefore the maps are rectangular. So this is a basic limitation from the texture side. Second is, that you simply need to make parts invisible in any way. By clipping or by transparency. And a humorous remark maybe. We maybe PLAY god with programs like this sometimes but we ARE NOT! So in difference to him (or her?) we have to deal with limitations!
Attached Link: http://www.md-arts.com/
Go to tutorials here. Look at the top ones. Shows how to do what you are wanting I think?Two reasons (or three?) maybe in my eyes why your result is different. #1 set your material setting to "object parametric" not to "world standard" #2 switch "decay near foreign objects" but those two maybe are not so relevant. and now... #3 my guess is that the patch of grass, relative to the object you want to be populated is way too big! Indication? Your only 358 instances. And what you maybe should understand is, that for the population only the center of the object is taken into account. So that you have a lot of overlapping from the patch of grass (sort of border) that covers your gap. You should try a test with for example the carex - and scale it down so that you get something around 10,000 items. Mine btw is the lawn material from Monsoons Ecowear material collection. He created some single grass plants so that this overlapping could not happen. You can see this "overhanging" as well by populating a terrain. Then you see that the patch of grass sort of hangs in the air, if you don't change that in the scale & orientation setting. But you see the "overhanging" too at the borders of your ground object - make a density of something around 20% as a test for that.
Sorry, Ecowear is available at 3DCommune - in the store. Under "whats new" i guess. LMcLean, how about giving me an email address via IM and i will send you an example material - as i did it. Of course NOT with Monsoons plants but with the carex, slightly modified maybe.
Wabe could you send it to me as well please. I tried to follow your instructions but when I got to the part where I selected the texturemap (black and white pic of the road) vue froze. Love esther esther@pacefiction.com
I aim to update it about once a month. Oh, and it's free!
okay, I can now load the texture map as I didn't have an alpha channel in it before which maybe why it froze but it still doesn't seem to do anything. Love esther
Actually I got it working now sort of. Doesn't look quite as good as yours. I'm using same ecowear grass as you wabe. Love esther
Message edited on: 01/06/2006 09:11
Yes i can try that. No problem. Good that thre was a sort of solution for you - even when it so far is not perfect. Keep in mind that i have only Cinema 8, not the latest version! Oh, my guess is that the reason for the problem is the missing uv coordinates in your ex-/import. Maybe you try another format for the import into Infinite?
