Sun, Feb 2, 6:12 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
Subject: glass figure
tartino ( ) posted Tue, 10 January 2006 at 5:01 AM ยท edited Sun, 02 February 2025 at 6:09 AM
Hi all with poser 5 I exported a figure dxf and 3ds to create in bryce a trasparent figure with a visible brain. The problem is that in the head, eye balls and teeth are grouped with the head. and they are visible with transparent textures. Any way to remove them (expecialy the teeth)? Or to export from poser as statue without internal parts? thanks in advance
neilp ( ) posted Tue, 10 January 2006 at 5:19 AM
Select the material zone for the teeth and set the Transparency value to 100%
tartino ( ) posted Tue, 10 January 2006 at 7:34 AM
thanks neilp, But the problem seems that if I export the figure as multiple objects group, the teeth are a single obiect with the head. I can't select teeth without select all head. And appling a transparent but reflessive texture to head, teeth are still a visible noise in image.
dadt ( ) posted Tue, 10 January 2006 at 7:43 AM
I would suggest that you export as OBJ and load into Bryce. You can then select the meshes for the teeth, inner mouth and tongue and delete them.The eyeballs are more difficult as if you delete them it leaves holes in the head.
tartino ( ) posted Tue, 10 January 2006 at 11:43 AM
thank you very much. Saved as .obj it works.
