Guess this function has a way limited range (compared with some already existing proximity features of the ecosystems). At least some shore-foam can be emulated without using memory-eating waterterrain-objects.
Here one try:
The most important thing is that terrains have to be clipped because the 'distance to object below' node just projects the xy-shape of the "object below" onto the water/ground plane.
Attached Link: http://www.renderosity.com/freestuff.ez?Form.Contrib=cspear&Topsectionid=0
You'll find my materials in Freestuff for doing exactly this. If you understand Vue 5 Inf's advanced material editing, you can have a lot of fun with them.Windows 10 x64 Pro - Intel Xeon E5450 @ 3.00GHz (x2)
PoserPro 11 - Units: Metres
Adobe CC 2017
Is it possible to make an object1 change it's color on those places where object2 is very close?
Eg coastlines: can I add a foamy water texture on my sea plane everywhere some terrains look out off the water?
I found a lot of input node options within the function editor but not an "object proximity" or somewhat.
Did I ignore something?
Message edited on: 01/11/2006 04:47
