Wish I could help. I have the one for M3 and tried to use it a few times and gave up. Way too complicated.
say." - Ghandi
Apply the texture of your choice to V3 before using HyperReal. When applying HyperReal, uncheck the "Use HyperReal Textures" at the bottom of the left column. Keep in mind that you won't be able to use any of the makeup options at the top of the right column if you uncheck the option.
The standard HyperReal V3 head texture doesn't have eyebrows.
Message edited on: 01/15/2006 18:23
As for changing the lipstick colors, you can either pick another texture just for the lips or change the color with the color dropper, I believe.
Ignore the white edges...I did something funky when I was trying to do my settings.
Message edited on: 01/15/2006 18:47
None of the textures in my version have eyebrows, any of the poses either. If I'm rendering in Poser, I usually use an older version of RealSkinShader that I've modified to suit my personal tastes. I like that it has separate controls for small and large spots, also the extra control over diffuse and ambient incidence. One of these days I'll have to figure out how to get Skin Tone and Brightness in the old version.
It looks like the transparency settings are at 1.0 but disconnected from theb transmap node. Deag that box to the right and see if it's the blue cords. If so, check the map (click on the eye) and make sure there are eyebrow markings at the top. A lot of characters come with eyelash transparency maps but not for the brows or pubes.
