Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
hmm..wonder about that. I did an 800hx600w background for the last pic in Bryce, everything's lined up and looking right, brought it in as a background, and Poser 4 tries to resize the puppy. Got it as close to 600x800 as I could, but then get a lot of pixelation and 'stair stepping'..wonder if that could be the same thing..;) @#$ thing wouldn't let me actually choose 600x800..go figure..;)
I just did a test. I imported a 1600x1200 background picture, and then rendered at 600x800, and the background maintained its own aspect ratio of 4:3, so the render had background grey above and below the background image which was squarely in the middle, like a letterbox movie.
Then tried changing the options to 800x600, and rerendered. Now the background had the sides open to the grey instead of the top and bottom.
And now it stays that way and probably will until I close and re-open poser.
Since Bart didn't say how large he was rendering we don't know. I don't think he was saying P4, as much as the P4 render engine. Then he said Firefly, not P6, so...
I still disagree that it's memory, I can render nice and large and it won't matter as long as I keep the aspect ratio the same for that session.
Message edited on: 01/19/2006 21:40
Oke thnx for the input I used a 1024x768 backGr. and render it at 1024x768 I have 3GB mem. so thats not the problem. The image work fine in p6 at P4 rendering. I played around a while and found out that it is a bit of Hit 'n Mis with it. Once in a while its A' OK render with the back in the right size. But the when nothing has changed by me " just clik Render again" ... Its dead wrong again... so Now i know i did nothing wrong... Its a Hickup in P6 for shure ... THNX antway U all for the input !! Chris "Not BART" :}
Not used anymore
I try to avoid using the background if at all possible. It seems to be very problematic, both in P5 and P6.
Instead, if I really need to use a BG pic, I use a 1-sided square, size it to EXACTLY the same dimensions as the pic, apply the pic to ambient, set everything else to 0 (black), ensure "cast no shadows", send the square waaaay back in Z then scale the square so everything is covered. It's a little more work, but seems more reliable.
And, although it's a little more work, for me, for the majority of times, it is quicker than coping with the BG's foibles...
The only problem I've encountered with this approach is if I need the scene to be lit from behind (ie. light in front of the camera: silhouette-type pics). There's no way to get an infinite light to shine through a square with a pic applied... (unless someone more knowledgable can tell me different -> insert "hope" emoticon)..
Cheers,
Diolma
Message edited on: 01/20/2006 16:42
Hi there When using a background image lets say 1024x768.. It looks OK in preview window... It renders OK in P4 render,nicely full in background. But now here it comes... In firefly render is wrong, dead wrong. It becomes Square !?!? compressed to the middle of the screen. And the rest is filled with the background color..... Is it me again that makes a error or is it poser again ? Anyone has a clue what wrong with it. I try lots of different things but notting makes it work the way i want it. Thnx Chris
Not used anymore
