Thanks, Dizzi. I found a script here that moves maps from the gradient to the bump node. It works, and I'm glad to have found it.
It's not really a good answer for "construction kit" type sets, though, since you have to run it for each item. And it doesn't work in Poser 5.
What I'd really like something that would allow batch processing.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2550918
Well, it's not quite batch processing, but it's pretty good. Nruddock has updated his Python scripts so they'll fix all the bumps maps in the scene. (Poser 6 only, alas.)This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Y'know, RDNA's Poser poll has 86% of respondents picking Poser 5 or 6. Only 6% picked P4, and 7% picked PP.
But DAZ still supports P4 and PP, not P5 and P6. I bought the Castle Creator set, and found it comes in with the bump maps attached to the gradient node, and looks pretty bad that way. Much nicer looking attached to the bump node.
But like most construction kits, it consists of a bunch of different figures and props, all pre-textured. If it had MAT files, I could use MAT Pose Edit, and if it was all one figure, I could use ShaderSpider, but I've never figured out a good way of handling construction kit-type things. Any ideas?
I should have known better, really. The textures for that fantasy castle they did for the PC had the same problem.
Gawd, I wish DAZ would step into the 21st century...
