Thu, Feb 20, 1:45 PM CST
Renderosity Forums / Animation
Welcome to the Animation Forum
Forum Moderators: Wolfenshire
Animation F.A.Q (Last Updated: 2025 Feb 18 8:03 am)
In here we will dicuss everything that moves.
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
[Animations]
Subject: cant animate........
Llez ( ) posted Mon, 23 January 2006 at 8:54 PM ยท edited Thu, 20 February 2025 at 1:43 PM
I use poser 5 and i cant get anything to animate correctly. Does anyone know of any good tut's i could use?
nemirc ( ) posted Mon, 23 January 2006 at 9:28 PM
There are plenty of tutorials by Dr. Geep in the Poser forum that might be of help. I had a link on the poser backroom during my "poser modding days" but it seems that somebody has removed them _
nemirc
Renderosity Magazine Staff Writer
https://renderositymagazine.com/users/nemirc
https://about.me/aris3d/
BTW animating is more than just moving bones. Maybe you should be more specific about what you need?
nemirc
Llez ( ) posted Mon, 23 January 2006 at 10:17 PM
sorry about that. when i animate a character, all the poses get mashed together so the character moves around really wierd and moves thru the floor and such. hope that was a little bit more specific.
Bobasaur ( ) posted Mon, 23 January 2006 at 11:43 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1866413&Reply=1866843
First the obvious... Individual poses are based on having elements keyframed over time. A turning head, for example, might have 0 degrees rotation on it's Y axis at the first frame and then be rotated 50 degrees on the 30th frame. If you wanted it to hold that position for a second and then return to facing forward, you'd set a keyframe - still at 50 degrees on the Y axis - again on the 60th frame and then one for 0 Degrees at the 90th frame. That's relatively simple. However, there are different kinds of keyframes. The spline ones try to draw a curve from keyframe to keyframe. They are extremely useful when you understand them but can really confuse you if you don't. If you used spline keyframe in the above example the head would actually go past 50 degrees between frame 30 and 60 and then come back. This is called overshoot. Linear Kayframes (the red ones) go exactly straight from keyframe to keyframe. The head would turn perfectly - but it's movement would be so perfect it would appear robotic and unnatural. The Constant keyframes (white) hold and exact position until the next one. The item doesn't move. The Break Spline Keyframes are spline keyframes but they break from what was before them and ignore it. By default, Poser uses Spline keyframes. If you select them and hit the Linear Keyframe button it will convert them to something more predicatable. As an addendum if you're setting up keyframes for multiple elements it's easy to forget about one's you've set. If I had forgotten to set the "stay at 50 degrees until now" keyframe on frame 60 in the example, the head would have continued moving until the 90th frame and it propossibly would have not moved the way you expected or wanted. What you are describing sounds like a combination of uncontrolled Spline keyframes and not having keyframes in place to keep elements from moving until you want them to move. As Nemirc suggested, Geep's tutorials are a great way to go beyond what's in the manual. Some of them can be found via the link but these are not all of them. Key words to look for are "animation" and "Graph Editor"
Miss Nancy ( ) posted Tue, 24 January 2006 at 12:12 AM
maybe Lez could get a jumpstart just by loading one of the animation Pose sets that come with Poser, and see how it works. but there will be problems if lez tries to apply a pose set to the wrong character.
InfoCentral ( ) posted Tue, 24 January 2006 at 9:41 PM
Attached Link: http://www.jefflew.com/
I can highly recommend this DVD. I got my son interested in animation by watching this on my TV. This isn't a DVD ROM so you can play it on your home DVD player.
samsiahaija ( ) posted Sat, 28 January 2006 at 2:14 AM
You might try to switch off IK for all body parts.
Even high end applications like Maya start messing up animations using IK: most professional 3D animators I know prefer the FK method.
Apart from that: get yourself the book 'The Animator's Survival Kit' by Richard Williams to learn about the fundamentals of character animation: mindlessly moving about body parts will rarely turn into great animations...
luvver_3d ( ) posted Sat, 28 January 2006 at 3:27 AM ยท edited Sat, 28 January 2006 at 3:27 AM
The ideal character rigs use a hybrid of IK/FK blending, which I don't believe Poser has. IK is almost always necessary when animating a walk cycle or footsteps.
Message edited on: 01/28/2006 03:27
nemirc ( ) posted Sat, 28 January 2006 at 1:29 PM
If you turn on/off the IKs during the animation, you will get anything but IK/FK blending...
nemirc
jimbo90125 ( ) posted Mon, 30 January 2006 at 9:47 PM
I don't understand why Poser has IK on/off switch. I thought IK/FK blending was industry standard by now, but I guess not. When I worked with the 3dsmax demo, that's the one thing I loved about Character Stuido. I could grab a body part from the top of the heiarchy or the bottom, it didn't matter. The skeleton moved as expected. No switching IK on or off. I'm sure Maya and other apps are the same in this aspect, so why not Poser?? Can you tell I'm frustrated with Poser's (lack of) intuitive animation tools? hahaha I can only hope Carrara is better.
nemirc ( ) posted Tue, 31 January 2006 at 10:00 AM
Because Poser's animation side is one of the less developed areas. Poser 6 has nice materials, it has cloth simulation and hair simulation, and even a nice renderer, but the animation tools remain unchanged. Well...
nemirc
