Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
When it looks for the Tegtreefull be sure and use the dropdown box when browsing for it to all files and then you will find it in the obj files folder. I kept getting that error untill I say what was happening and it was looking for a pz3. Hope thats not confusing. Its hard to ungroup an item when you can not get it loaded into Vue. :) Maybe Irish can tell us what is best solution to the problem. :)
ïÏøçö
Attached Link: Updated Ecosystem Zip
My apologies! I have updated the file to reflect that it should be looking for Tegtree.obj instead of the pz3 file. I hope you will still give it a try. If you want to download it again, you can do so in the attached link or above. Again. my sincerest apologies - but, it's still a good ecosystem :) :) IreneThanks Irish. I tried and tried but I couldn't figure how to get it working. Your setup isn't the same as mine, I don't have Vue in the same folders, Program Files/e-on software/Vue Infinite/etc. So I tried just extracting the sub folders under Vue Infinte. Well they installed but now I can't find the ecosystem material. I've got the ground, grass, and the tree objects; teg-grass, teg-rockpile, and tegtree, But not the ecosystem material. Either that or I'm just confusing myself. It is getting kind of late.
Oh my gosh, is my face RED! In all the redo's I have apparently forgotten to add the most important file, the ecosystem itself!!!!!!!!! I have AGAIN corrected the zip so please download again and while you're at it, give me a swift kick in the derriere. What a learning experience this has been!! I have also changed the path of the files. Sorry about this, honest I am...I am...I am... :) Irene
The last one you uploaded with the missing ecosystem file is still looking for a Tegtree pz3 file when it should be a Tegtree.vob. I can change browser window to all files and broswe to the obj folder and select it and it loads ok. Some little something just not right with a path when its trying to find the Tegtree.vob. Other than that it works as it should.
ïÏøçö
This is a message for Irish. You should save the items you want to use for the ecosystem as vob first, with the option "including all textures" (have no Vue at hand right now so the words may be wrong). Then use those vobs for the ecosystem. Save the eco as material, again with the same option switched on. Then you should not need anything else than this material to give to others, it contains all necessary information to be used by others. Look at some eco materials that come with Vue for example. The objects used there are not available anywhere else. I think this is a cool option, you don't have to be worried about textures, obj originals or pathnames at all.
Thanks Walther,
That one goes into my permanent EcoSystem notes :o)
_ jc...'Art Head Start' e-book
.......Art Head Start.com site Art skills for digital artists. Free lighting chapter, tutorials.
Thanks Wabe. I have all the objects used in the ecosystem saved as .vobs. For some reason though, since the tree was originally saved from an object I created into a prop in Poser, and saved as a pz3, it still keeps looking for it instead of the .vob. I redid the ecosystem beginning from scatch, so I am not sure what the problem is. Since the tree is there as a vob, people should just be able to load it into the ecosystem instead but I will try and sort it again. One of the difficulties is that I have various updates on the computer so I need to erase everything and start from the beginning. I guess I am just going to tuck this whole experience under my belt as a good learning one!! :) Irene
Attached Link: Into The Woods - Ecosystem and Tutorial
Just in case you'd like to try this out, I've posted this on my website - the zip file is included as well.Using this ecosystem I have made a number of images, the last one using only a procedural terrain, which turned out like this:
http://www.renderosity.com/viewed.ez?galleryid=1141531
You can find the Tutorial and Ecosystem Zip at the link.
Thanks and I would love to see what you create with it!!
Irene
