Sun, Feb 9, 5:05 AM CST
Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Subject: Canon EF25 Extension Tube
MaydaMason ( ) posted Wed, 25 January 2006 at 4:36 AM · edited Wed, 05 February 2025 at 2:33 AM
good morning! i need once again your help... i've seen this accessory... someone of you has this? what are results? what kind of objective works good with it? may i obtain the same result than usin' the 100mm macro from canon? someone of you has some example shots? thank you for the help!
Mayda
MaydaPhoto
danob ( ) posted Wed, 25 January 2006 at 9:42 AM
Hi well extention tubes will allow you to get greater than 1/1 but are not a substitute for a good macro lens rather as an aid to it.. They allow closer focus when placed on most lenses, but be aware that they will not work at the longer focal length. As there is no glass it is worth considering a set of Kenko ones when a set of 3 can be obtained for the price of the EF25 the Canon is much better built but nothing in it from the optical point of view..
Danny O'Byrne  http://www.digitalartzone.co.uk/
"All the technique in the world doesn't compensate for the inability to notice" Eliott Erwitt
MaydaMason ( ) posted Thu, 26 January 2006 at 1:42 AM
thanks!!!! i've found kenko solution as the same price!
Mayda
MaydaPhoto
