Thanks Eowyn S And you are welcome. I figure I have used enough stuff from the web S These are just ones I had from pictures I did and most of them are just using Zygote morphs. The guy in the upper left is the one that was the Sean Connery one without the mustache. Well Macbeth but you called him that. The brow is much better with the trans maps and stuff. I normally try to do as much as I can with the Zygote ones as I can. When people say they don't do anything I just have to raise a brow sometimes since most of these are from them. I normally do morphs on a as needed basis but I can do some just cause. So probably I will be doing mostly characters. S
Thanks for link. The Michael faces at 8M are the same (plus a couple) that are at DAZ. I've been spoiled by the large library of Schlabber's faces plus some additional ones picked up here and there. Given the extreme detail of Michael's face, facial close-ups, even extreme close-ups (ECU) are now possible in Poser. Facial expressions are perhaps the best way to express feelings, emotions, intent, etc and it would be super peachy keen if there was a library for Michael half as big as there is for P4. Your work shows just how much can be done with Poser for different head types. Waiting to DL your stuff..
Gordon
![file_157466.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_157466.jpg)
Okay .. I need to get the morphs stripped doown (have the two center ones done) but here is a preview of some of the faces that will go into freestuff. Just left overs from stuff I did. 99.9 percent of the morphs are just just he zygote ones. Let me know whatcha think.
