Sat, Dec 28, 2:42 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: Help with Seam Gaps on V3 texture
BorgBoy7 ( ) posted Sat, 28 January 2006 at 2:40 AM ยท edited Sat, 28 December 2024 at 2:33 AM
I recently noticed a change in some of my models in Poser 6. There is a gap in the seams that did not show before, is there a setting in poser that fixes this texture gap? I think I saw another thread talk about this but I haven't found it again yet. Can anbody help
jt411 ( ) posted Sat, 28 January 2006 at 2:48 AM
This might sound like a dumb question, but does the seam show up in the render?
bucketload3D ( ) posted Sat, 28 January 2006 at 5:21 AM
It is normal to have seams visible on some textures in the preview mode. If the seams show up in the render too, you might want to turn "texture filtering" off, or use P4 renderign engine.
www.Bucketload3d.com - where cool freebies are ~(==^..^)
richardson ( ) posted Sat, 28 January 2006 at 7:03 AM
Yep. Normal in preview mode.
BorgBoy7 ( ) posted Sat, 28 January 2006 at 8:03 AM
Left to right, filter on, filter off and P4 render with anti alias on. Looks like part of the problem is in the texture itself, but I did learn something new about render settings. Thanks for the help guys. BorgBoy7 "...Resistance isn't the best way to learn..."
bucketload3D ( ) posted Sat, 28 January 2006 at 8:12 AM
It happens because many merchants create textures with skin-color filled background and many (as in your case probably) with white background on which the texture itself is placed. Firefly blurs the texture a bit, especially with the filter on, so that there is no ugly moire effect on higly detailed images, and the white color from just beyond the edge of the texture bleeds into the texture itself. Poser 4 renderer doesn't do that. But then again, P4 renderer doesn't do many other wonderful things :) At least it's how I understand that. kitty5
Jules53757 ( ) posted Sat, 28 January 2006 at 1:06 PM
Try to increase max texture size in the render options to max.
Ulli
