Sat, Feb 1, 5:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Question to POSER PRO PACK users
pvlassov ( ) posted Wed, 21 March 2001 at 8:46 PM ยท edited Thu, 30 January 2025 at 11:22 AM
Hi, I am just deciding to purchase Poser Pro Pack and i am wondering whether it is a good thing to do. If there is someone out there who can briefly tell me pros and cons of PRO PACK so that i can make my decidion. Does PRO pack create a .fla file so that i can edit my flash animation in Flash?
dunga ( ) posted Wed, 21 March 2001 at 11:03 PM
wait until curious labs fixes their plugin for 3ds max!!!! other wise frusrtation is guranteed
bushi ( ) posted Thu, 22 March 2001 at 1:06 AM
It depends a lot on what you're going to do with it. I haven't worked much with the new setup area but I understand that it makes creating figures much easier. I've be working pretty much exclusively with the PoserPython scripting feature and couldn't be happier with it. IMO the most significant improvement since P3 added the Zygote figures.
thip ( ) posted Thu, 22 March 2001 at 2:48 AM
You can d/l the user guide from Curious at http://www.curiouslabs.com/downloads/index.html. It's a quick read, and it will give you all the info you need to make an informed decision. They also have several Flash examples you can have a look at (I don't do Flash myself, so I haven't checked them out, but I've heard they're good).
lalverson ( ) posted Thu, 22 March 2001 at 11:43 AM
Online Now!
I bought it mostly for the compression stuff it does with rhe PZ3 and cr2 and obj and in that alone works well , but the additional applications like cr2 editor and Morph manager will not see those files to work with them, so i ended up turning that off. POSER does seem to lock up less and run smoother ( altought a little slowewr). With eve vaients it makes a new obj and puts it in the same folder as the Cr2 and in the case of the eveV2 (with real eyes) it adds a new material and adds that map the the mesh. so the next time you load it you have to re load the eye texture and set the "Cornea" material to clear and shiney. Sadly there is no short answer as to is it good to buy or not. In some ways it is better and others not so, but since I don't use the not so's then it really your call.
pvlassov ( ) posted Thu, 22 March 2001 at 3:30 PM
Thanks a lot people, Looks like i might as well wait a little
