Wed, Feb 5, 10:12 AM CST
Subject: Dumb Wardrobe Wizard Question
tvining ( ) posted Sun, 29 January 2006 at 11:04 AM ยท edited Wed, 05 February 2025 at 10:10 AM
This always screws me up (as it just did after analyzing for an hour), so, before I waste another hour, could somebody clarify two things for me that aren't clear in the WW directions: 1) when you push the "Convert from figure" button, which should be selected: the (human) figure or the clothing item? 2) when you are done analyzing, and have deleted the "from" figure and have brought in the new figure you want the clothing to fit, I have the same question: should you have the figure or the clothing item selected when you hit the "Convert to figure" button? Thanks--T
artistheat ( ) posted Sun, 29 January 2006 at 12:57 PM
I always select the clothing that I'm working on.
AtelierAriel ( ) posted Sun, 29 January 2006 at 4:30 PM
You're not altering the figure, you're altering the clothing. So Convert to...refers to the clothing. That's what you're trying to make fit. Convert clothing from one figure then convert the clothing to another.
Acadia ( ) posted Sun, 29 January 2006 at 6:06 PM
Wardrobe Wizard deals with the clothing....so unless you are zeroing the figure itself before you start, always have the clothing selected.
tvining ( ) posted Sun, 29 January 2006 at 8:05 PM
Thanks!--T
Lyrra ( ) posted Mon, 30 January 2006 at 5:00 AM
and when you are doing adjustments after the fitting (using the smooth or expand options) make sure you have the Body or bodypart of the clothing selected that you want to change. if you want to change the entire clothing item use Body.
