Sat, Jan 11, 9:43 AM CST
Subject: Object/view in main screen
BUSHY8996 ( ) posted Mon, 30 January 2006 at 9:44 AM · edited Sat, 11 January 2025 at 6:54 AM
How do I set things up so that when I laod a poser figure/object - it loads in the front centre of the sreen? At he moent it seems to load in the far distance & it takes alot of time trying to bring it to the front. I have also notice that any load or improted object is displayed as a black box - how do a set the options so that it takes the shape of the actual model - thus making it easeir to position ect?
Peggy_Walters ( ) posted Mon, 30 January 2006 at 11:23 AM
Click File, Options, and make sure that Resize and center imported objects is checked on the Object options section. If your item still comes in off center, make sure you are only selecting the figure/object in Poser, not the ground plane. Don't know why they are not being displayed. Maybe a open GL problem?
LVS - Where Learning is Fun!
Trelawney ( ) posted Mon, 30 January 2006 at 7:19 PM
Hi Bushy The black box is the default bounding box that Vue puts around objects when it first imports, but if you leave it for several seconds (and haven't disabled any of the draw thread/display options), the box will gradually decimate into the shape of the imported mesh. (Faster systems will decimate the mesh faster). If Resources drop below a certain RAM % level, then Vue will revert back to the box to lower the memory used. Peggy was right correct about Resize and Center objects >8o) Hope this helps. Kind regards
