Sun, Feb 2, 11:12 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: new 2 pc - where should runtimes be? (normally a mac user)
estherau ( ) posted Thu, 02 February 2006 at 7:54 PM · edited Sun, 02 February 2025 at 11:09 PM
hi, i have a pc now and i bought the pc version of poser 6 as ef offered me a nice deal. so now i have pooser 6 on both my puters. but i was wondering for nax speed if i should but everything on the c drive. ny c drive is bot as big as my other internal drives (mostly ide reackmounts). love esther
MY ONLINE COMIC IS NOW LIVE
Acadia ( ) posted Thu, 02 February 2006 at 7:55 PM
Any drive will do. I have poser on my C drive, and runtimes on my C drive. However, until my external drive gave up on me, I had my runtimes on E drive.
anxcon ( ) posted Thu, 02 February 2006 at 8:14 PM
tip, partition the drive into 3 C: windows/system stuff, very small, 5gb is plenty for winxp D: major programs, poser/psp/etc E: runtimes, saved pics/projects/movies/etc, library drive the reason for it split up, is programs defragment quickly ie the file parts aren't sorted as efficiently as can be so easy to defrag a drive, and keep poser a bit faster drive C and D defrag like once a week drive E is more perm files, you and poser wouldn't really be moving/editing them much, so thats why they're seperate
estherau ( ) posted Thu, 02 February 2006 at 8:30 PM
i already have separate E and D drives though
anxcon ( ) posted Thu, 02 February 2006 at 8:52 PM
seperate (physically) harddrive? keep one for backups having a hd crash is bad :( unless you're happy burning CD/DVD for backups above is my hd setup, just 1 hd though 160GB F: my CD-burn/DVD-rom (old internal, should take out) G: CD/DVD burner external, i just burn the main backups to DVD
estherau ( ) posted Thu, 02 February 2006 at 9:20 PM
i have some of those rackmounts i can popout and use for backups love esther
anxcon ( ) posted Thu, 02 February 2006 at 10:16 PM
those are fun ^_^ but anyways, point remains, programs on 1, library on the other :P
estherau ( ) posted Thu, 02 February 2006 at 11:24 PM
Or library on a different partition of same hard drive - would that be faster? Lvoe esther ps yeah - fun
DRACONIAN ( ) posted Fri, 03 February 2006 at 12:25 AM
Attached Link: NetherWorks's Studio
Hi Esther! Actually, "Logical Drives" or secondary partitions are slower. Let's say your 160gig HD is partitioned in 2(C & D). C will be faster to access then D. & if you had a second HD partitioned in 2. The first partition of that drive would be again faster then the second partition... But, Anxcon is correct! It easier to backup a smaller partition like 5-10 gig(C: for example) with just windows all setup nicely. That way if God forbid(it crashes bad), you'll be able to restore that in 5 minutes... ;-) Anywoo... Just remember to use "Correct Reference 1.1" available at this link. It will help fix "Non-relative" links in your library files(just read the technical bit on that in your email) :-)) Have a Great Day! Marcus
estherau ( ) posted Fri, 03 February 2006 at 7:38 AM
Okay, so proggies on the C drive and my runtimes elsewhere. It's just that poser is so sluggish I was hoping I could find some way to speed it up. I put 2gig ram, and it did make it a little zippier. Love esther
estherau ( ) posted Fri, 03 February 2006 at 7:39 AM
Wish I had a machine like yours marcus!
Ghostofmacbeth ( ) posted Fri, 03 February 2006 at 10:25 AM
Ewwww PC ;)
DRACONIAN ( ) posted Fri, 03 February 2006 at 2:52 PM
Well, i wish i had your Mac Esther! :-)) But, i can build 3 PCs like mine for the price of 1 G5. So, it's mostly economics that tipped the balance. Cause, i like both Mac & PC... There are things you can do to speed things up a bit. "optimizing" WinXp for instance. You can easily disable 20+ services(That you will never use). I'll write you a tutorial on how to do that. The "footprint" of my WinXP pro is 105 megs in the RAM. Most people's would be between 160-200. That alone helps a lot. Also, my 3D Putter doesn't have any Norton utilities on it. The reason is simple, Norton apps take away lots of resources. Instead i remotely scan for viruses on it via my older putter. :-) Consider also, that i have only PPP. So, it's much faster to load 20 V3s + clothes. With P5 or P6, it would probably be more like 5-6 V3, then things would get sluggish My upcoming "Throne Room" will be a good test for your putter cause it will have lots of textures & around 150,000 polys. Dolce Sogno! Marcus
PilotHigh ( ) posted Sun, 05 February 2006 at 12:50 PM
bookmark
