Sat, Feb 1, 4:55 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: model conversion help
MungoPark ( ) posted Thu, 02 February 2006 at 12:31 PM ยท edited Sat, 01 February 2025 at 4:51 AM
I have this model sitting around on my HD for a long time - I can not find the original site from where I downloaded it anymore - its gone (and the archive has no readme). What I know it was a Russian site called Diamond Design. Its a Tucker TT48 and I want to bring it into Poser. The original file is a highly detailed .lwo.
I can bring it into Cinema - export it as an object and then Poser crashes when importing the object. I am on OS X - so I have no conversion utilities. The render is in Cinema.
Help converting it ?
dadt ( ) posted Thu, 02 February 2006 at 2:22 PM
Poser should import the Lightwave file without conversion, its in the list in "import object"
MungoPark ( ) posted Thu, 02 February 2006 at 2:37 PM
Poser crashes when I do this.........
Jules53757 ( ) posted Thu, 02 February 2006 at 4:27 PM
Attached Link: http://www.simplylightwave.com/download_pages/object.mhtml?oid=110&catid=34&typeid=4
Try the link, I didn't check it, 'cause I'm not on my PC but as long as I remember it works in Poser.
Ulli
JunkoH ( ) posted Thu, 02 February 2006 at 4:30 PM
Poser will only import Lightwave 5.6 format (no UV's). This model is currently hosted at simplylightwave.com and there is an email listed for the author (may no longer be valid). I brought the model into Poser as an OBJ (100K+ polygons) but didn't do too much with it since the wheels are locked at a 20 degree angle and I couldnt find a good pivot point
UVDan ( ) posted Thu, 02 February 2006 at 8:38 PM
Forum Moderator
I have heard that you can use poseray to convert lightwave files.
ellocolobo ( ) posted Thu, 02 February 2006 at 10:17 PM
I'll do it for you..Just send the file..rnlobo@yahoo.com
MungoPark ( ) posted Fri, 03 February 2006 at 1:09 AM
Thanx for the help - its already converted
