Sun, Feb 2, 8:11 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: poser 4 personal settings not saving!
Deal ( ) posted Thu, 22 March 2001 at 1:31 PM ยท edited Thu, 30 January 2025 at 1:19 PM
Has this happened to anyone else? Every time I set my Preffered state, it reverts to the original "factory" state. The only things that stay are the figure and the size of the modeling window. But the window always moves to the original spot,This seems to be happening ever since that damned 4.03 patch!!!!!
Gunbuster ( ) posted Thu, 22 March 2001 at 2:38 PM
I get this as well, what I might have to do is make my default states then install the patch afterwards
RealitysPoison ( ) posted Thu, 22 March 2001 at 4:30 PM
Happens to me as well. I never took the time to find out why. I just set a UI dot and use that to get it back to the way I had it. Maybe someday I will take a look at it. Guess when I open up poser I have too many ideas to bother :)
Deimos ( ) posted Thu, 22 March 2001 at 8:00 PM
I had this happen again this happened after I installed one of the patches after poser 4.0 I don't remember which one. what patches if any have you others installed?
Deal ( ) posted Thu, 22 March 2001 at 8:07 PM
I instaled the first one that came out a while back. But this didnt happen until I installed the latest one.
Abraham ( ) posted Fri, 23 March 2001 at 12:58 AM
Should try to organise your workspace the way you like it and then to save the file as default in the poser folder. It worked for me after the install of the 4.3 :) J-L
bloodsong ( ) posted Fri, 23 March 2001 at 10:58 AM
heyas; this happens because.... of something weird in the windows shortcut to the program. i think it's the 'starting directory' setting. the cure is to either delete the shortcut and re-create it, or edit the shortcut and make sure all the pointers are pointing to your actual poser directory.
Gunbuster ( ) posted Fri, 23 March 2001 at 2:05 PM
Thanks Bloodsong, your a star
Deal ( ) posted Fri, 23 March 2001 at 4:26 PM
Thanks I can always count on this forum for info.....I just wish I could be of more help to others.. 8^)
bloodsong ( ) posted Fri, 23 March 2001 at 5:30 PM
heyas; you're welcome, but i didn't discover this fix. it was scotta, i believe. :) but i feel your pain! i had this condition for months before he figured it out.
