Mon, Dec 2, 7:14 PM CST
Subject: Texturing Back-facing Surfaces
baggettbear ( ) posted Mon, 06 February 2006 at 4:40 PM ยท edited Sat, 30 November 2024 at 8:23 PM
Hello, I'm not sure if this is possible, but I would like to texture the inside of a piece of clothing which was created with only the external surfaces set to show textures. For instance, I'd like the back of the shirt in this image to be visible when seen from this angle (without it being worn by a character). Thanks for any guidance provided.
Mike
dadt ( ) posted Mon, 06 February 2006 at 5:02 PM
The problem is that its a single sided mesh and won't take a texture on the rear face. I've had this problem and have not found an answer but will be very interested if anyone can come up with a solution.
nruddock ( ) posted Mon, 06 February 2006 at 5:07 PM
Everything will show up when rendered, provided you uncheck "Remove backfacing polys" in your render settings, and check "Normals_Forward" on all relevant materials.
baggettbear ( ) posted Mon, 06 February 2006 at 5:20 PM
Wow... works great! Thanks for the quick response.
Mike
