Tue, Feb 4, 2:34 AM CST
Subject: Atmopsheric Animation in Vue 5 problems
spikboi ( ) posted Wed, 08 February 2006 at 4:00 AM ยท edited Fri, 31 January 2025 at 4:00 PM
Hi, I want to animate a sunset in Vue 5 esprit so I select the atmosphere I want and all the parameters etc... then I hid the sun underneath the ground plane. What I can't achieve on the timeline is some way to get the atmospheric colours to change while the sun is moving up. Also I when I bought Vue 5 esprit I was told that it could animate environments, trees blowing in the wind, water moving etc... but I can't see a way to get this to work either!! Help!!!
bounzer ( ) posted Wed, 08 February 2006 at 9:40 AM
RTFM Cheers, bounzer.
spikboi ( ) posted Wed, 08 February 2006 at 9:46 AM
It didn't come with FM. I wouldn't ask if I had it would I?
surveyman ( ) posted Wed, 08 February 2006 at 3:01 PM
All the information that's in the manual is also in the HELP files. The suggestion above is for you to look it up. I believe that somewhere in the installation on your hard drive there should be some form of documentation. Go through your directories. E-On also has an option to order a hard copy manual. Something to think about.
impish ( ) posted Wed, 08 February 2006 at 5:08 PM
You can edit the colour of the sunlight in the atmosphere editor. Select the first frame of your animation. Open the atmosphere editor and change the light colour and ambient light colour. Now move the time line on to the end (or next colour change) you want to achieve. Go into the atmosphere editor again and change the same parameters. Hope that helps. Cheers Mark
Jumpstartme2 ( ) posted Thu, 09 February 2006 at 1:40 AM
If Im not mistaken, there is an animated sunset in the material editor...
~Jani
Renderosity Community Admin
GPFrance ( ) posted Sat, 11 February 2006 at 7:54 PM
Attached Link: http://www.ditsch.fr/gpfrance/gratos/indobj.htm
There you find an animated sun (Vue5Inf) to download free : 24 hours trajectory compressed into 24 seconds timeline. Isolate the time slice you want, spread the keyframes to your timescale, and animate what you want to : intensity, colour, flare, clouds...
