Forum Moderators: RedPhantom
suggestion, take it or leave it:
small steps, from the simple on out.
work with James, not casual james.
with James in default position, apply some dynamic hair, like James_Layer or James_Messy.
the hair should pop into the correct place.
do not do any animation. do not change the pose. render immediately with firefly.
your pixel samples should be set to at least 3, and the min shading rate to, say, 1.0 for now.
BE SURE THERE ARE NO RAYTRACE SHADOW LIGHTS, that Raytrace is off in render settings, that you have no IBL lights and certainly no AO selected.
do you like the results? (you are using all defaults, how do they look as a start, in other words.)
Post an image, please, if you can.
::::: Opera :::::
Message edited on: 02/09/2006 23:34
Attached Link: http://www.adorana.de/downloads/
If you are going to try making your own hair in the Hair room, I hope you have a very very very powerful computer. It takes a huge amount of resources to work in that room. Have you tried Dynamic Hair? You might want to have a look in your Poser 6 runtime in the Jessie Hair folder to see what hair in the hair room tends to look like. It's called "strand based"."It is good to see ourselves as
say." - Ghandi
Is there water in your future or is
it being shipped away to be resold to you?
Water, the ultimate
weapon...
www.futurefantasydesign.com
Operaguy! It is a bit late now but I will that tomorrow!!! I think part of it is I am not sure what works with what, if i use V3 and Aiko almost exclusively is there any of the P4 or 5 Hair that will also work with them?> More later Good nite all Midnite here got to go to bed. CM
Water, the ultimate
weapon...
HAIR 101 There is prop hair. Then there is dynamic hair. They are completely different. You can't fix prop hair in the hair room, and dynamic hair has no morphs, it can only be attacked in the hair room (aside from translation x/y/z and scale) So, to make this easier, pick 1 hair, the one you feel best about, and work with it until you understand it. So, if you wish, please pick your hair and report if it is dynamic or not. Also report what character model you are working with. Thanks.
Water, the ultimate
weapon...
Hi I work exclusively with V3 97% of the time. 99% of the hair I buy is for V3. Liltsure and Sherrie Hair are all Dynamic I believe? Heck I'm not sure! The reason I posted about the Firefly is that is the render you asked me to use. I seem to get great results with P4 renders, but until the post last nite i never considered if it made a difference. CM
Water, the ultimate
weapon...
To change the Firefly settings, drag the black triangle between "Draft" and "Final" left or right to change (this is for "Auto Settings").
If you want more control over the settings, click on the circle next to "Manual Settings", then on the "Acquire from Auto" button that appears.
For a more detailed explaination, refer to the manual.
Liltsure and Sherrie hair are both Prop or as some say Conforming Hair. The "gaps" in Liltsure hair they do know about and said it was an option between versitility and movement against a smooth top and they went with the former. (not thier exact words) That hair I have found is best used from a slightly turned angle more then head on. Dynamic hair is more hands on and has a totally different look to it. Ill try to post some pics later on of how it looks.
I have two books, Poser 6 Revealed, and the Reference Manual that came with P6. I cannot understand the verbage of either! I need to learn to do Hair cause most Preset and morphing hair is too unrully for my needs. Or boring. Can someone who is good at hair give some simply worded help to me? I don't understand what is needed to start, I thought it was a skull cap but apparently I am wrong. I do some nice post production hair but som guides would improve that immensly too! ThanX!!! CrimsonMoon
Is there water in your future or is it being shipped away to be resold to you?
Water, the ultimate weapon...
