Mon, Jan 27, 6:51 AM CST
Subject: Which is better - obj or 3ds?
Neyjour ( ) posted Fri, 10 February 2006 at 6:22 PM · edited Mon, 27 January 2025 at 6:35 AM
If you have a model in both .obj and .3ds format, which one is better for use in Poser? Are there any significant differences between the two? Or does it really not matter?
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
bandolin ( ) posted Fri, 10 February 2006 at 6:25 PM
.obj. 3DS is an old format with alot of restrictions. There are alot of significant differences, but I'm no techie. Someone will chime in with specifics I'm sure.
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
wheatpenny ( ) posted Fri, 10 February 2006 at 6:28 PM
Site Admin
They both have their advantages: obj's tend to hold their textures better. 3ds has a smaller file-size, so it's frequently easier to render (although it doesn't always make much of a difference). Sometiems 3ds files won't import - there are apparently variations in the 3ds format and poser won't accept some variations. I guess the best thing would be to try importing both and see which one works better for you.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Neyjour ( ) posted Fri, 10 February 2006 at 6:36 PM
That's very helpful! Looks like I will be going with the .obj format then. Thanks very much both of you! :)
Little_Dragon ( ) posted Fri, 10 February 2006 at 11:39 PM
Someone will chime in with specifics I'm sure. 3DS files are always triangulated, and group names have a limit of ten characters.
arcady ( ) posted Sat, 11 February 2006 at 3:03 AM
obj files may or may not be triangulated by the way. From what I'm learning somtimes you want triangles and sometimes you want squares. If you plan to 'rig' the import into a figure I suggest importing both and seeing which will pose better. On the other hand, if the person saving it made a 3ds, and those are always triangulated, then they probably made the obj in the same manner, though that is just a guess.
Truth has no value without backing by unfounded belief.
Renderosity Gallery
stonemason ( ) posted Sat, 11 February 2006 at 3:44 AM · edited Sat, 11 February 2006 at 3:45 AM
the only time you should need a triangulated mesh is for cloth that needs to fold & move in a realistic way,& even then you'd be best having a Delaunay triangulation.
.obj is a better all round solution
.3ds polycount is limited to 65536 per mesh & normals aren't supported,
Message edited on: 02/11/2006 03:45
Cg Society Portfolio
AntoniaTiger ( ) posted Sat, 11 February 2006 at 5:25 PM
For Poser, the normals stored in a file are irrelevant. What Poser uses is derived from the order of the vertices in the facet line. This can sometimes result in a part of an imported mesh having the normals facing in the wrong direction.
infinity10 ( ) posted Sun, 12 February 2006 at 7:37 PM
bookmark
Eternal Hobbyist
JHoagland ( ) posted Sun, 12 February 2006 at 8:05 PM
All Poser models (figures, hair, and props) reference external obj files (not 3ds files)... so you should use obj files. :) --John
VanishingPoint... Advanced 3D Modeling Solutions
spinner ( ) posted Mon, 13 February 2006 at 12:12 AM
Poser is no fan of Delaunay wires, though ~s
rreynolds ( ) posted Mon, 13 February 2006 at 1:04 PM
Any 3ds file much bigger than 1 Mb is likely to crash Poser. An Obj can be 100 Mb and still be loaded, though Poser will cry and be unbelievably sluggish.
Neyjour ( ) posted Tue, 14 February 2006 at 2:05 AM
Thanks again everyone! I will definitely go with .obj whenever possible. :) Usually it's not an option, a model is either in one format or the other, but now that I have high speed I was wanting to download some of rodluc's castles, and some of them are available in both .3ds and .obj format ... so that got me to wondering.
