Mon, Dec 2, 5:15 PM CST
Subject: Hybrid Cloth Problem
sudi ( ) posted Sat, 11 February 2006 at 3:59 PM · edited Sat, 30 November 2024 at 3:00 PM
Hi.,, I `ve problem with hybrid Cloth setup . It seems not work for me because V3`s or any poser figure`s legs not shown in my colide tab
This is my step for hybrid Cloth
  1. Load V3
  2. Load Morphing Fantasy Dress
  3. Conform to her
  4. Go to to Cloth Room
  5. Set Simulation
  6. Push Clothify button ( FMD =hip )
  7. Colide ....?????
Anyone know , where hip , buttock , leg ..etc gone ?
svdl ( ) posted Sat, 11 February 2006 at 4:21 PM
I've seen this happen too. Apparently Poser gets confused when a body part that conforms to another figure (in this case the hip of the MFD conforming to the hip of V3) is turned into dynamic cloth. The solution is editing the .CR2 file of the cloth. Rename all instances of "hip" to "skirt". Save as MFDHybrid.CR2. You'll also have to make a different .OBJ file with the correct groups. The best way is importing the MFD .OBJ file from the Geometries subfolder into Poser, enter the Grouping Tool, choose "New Group", name it "skirt" (capitalization is important!) and add all polygons from the hip group. Then switch to the Setup room, apply the MFDHybrid.cr2 figure to get the correct bones and morphs, and save back to your Figure library. Now you should have a MFDHybrid dress that conforms on top and has a dynamic skirt. And all the morphs still work. Hope this helps, Steven.
My gallery   My freestuff
sudi ( ) posted Sat, 11 February 2006 at 5:38 PM
Thanks for quick response !! great Community
Acadia ( ) posted Sat, 11 February 2006 at 8:43 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2517340
Trying to use Conforming clothing in the cloth room doesn't work in Poser 5. You need to edit files in order to get it to work.... and then it doesn't work all that well anyway. My reason for upgrading to Poser 6 in December was because I wanted to use the MFD in the cloth room and couldn't with Poser 5. See the above link for more information on using conforming clothing in the cloth room.
