Great! The lips and nostrils are the points that has always given away Posette AS Posette more than anything else. These will help a lot! Thanks!!
You justย can'tย put the words "Poserites" and "happy" in the same sentence - didn't you know that? LaurieA
ย Using Poser since 2002. Currently at Version 11.1 - Win 10.
radstorm, this is done the old fashion way, what I like. You double click on the head of Posette to bring up the Properties, there should be an add morph object button (this is also on the main window menues as well)... a box pops up asking what the name should be (as it is to apear on the dial) then click for choosing the file and look for Stahl's .obj. You must repeat this for each seperate morph. You must then save this figure to you figure library. Stahlratte, excelent! Thank you. It was the lip that always held me up with Posette. I am realy apreciate the work you are doing :)
..and how do you call them up to use in Poser? Unzip the file to your desktop. Open Poser and load Posette. Click on the head. Then "Object"--->"Load Morph Target" Choose one of the obj files, and a name for your new morph dial, click "OK", and set the dial of the new morph to "1" Do the same with the other file. After you loaded all files, save that Posette to your figure library. stahlratte
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1158123
And some people think Posette is dead ...Thanks again, stahl ;)
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
Attached Link: http://www.deviantart.com/view/29160207/
Heh. Thanks, Pangor ;)It's incredible how the Poser6 new features (and the work of artists like stahl or PitKlad) can improve Posette to convert her in a completely different model :)
I did a curious experiment at my deviantArt account. dA isn't a Poser or 3D based community, so there Posette isn't well-known ... this is the result ;)
EDITED to add the @#$%&* nudity tag, grunt
Message edited on: 02/18/2006 01:59
CASETTE
I could not see the links to picture,"adult filter on", but I know what it was because of see the same comment for the first time at PF. You know something, all the talk about the Mil. people being so much better looking, is all so much hogwash. Out of the box, they are the same as a Posette out of the box. Or maybe not even that much, because they don't have the bultin morphs that Posette, Dork, Don, Judy, etc have. They are not better just different. It takes a lot of work by the artist or someone else to make those models look good. If it were not for the work done by others to make a V3 look good she would be seen as Posette's inferior cousin. It is ammusing when we create new characters form Posette, then people react by saying, "That is Posette?" I had the same reation though with Jessie. After seeing many promos of her and not being impressed, I saw a render of her that I was quite impressed by. But in that case the impressive render was one in which Jessie was used out of the box!
The somnambulator has awakened!
EDITED to add the @#$%&* nudity tag, grunt Yea, dealing with nudity flags can be a pain and and can by silly at times. But that is the standard of the site, so we follow them. ;-) The reason that for the "adult filter on" at deviantArt is because I was viwing as guest, since I don't have an account there.
Millenium and unimesh people have better joint points and better rigging system. A matter that a 3d modeller could fix, just as stahl is doing with her little bugs Desesperately watching ValeriV3 ;) And Jessie... heh. Some people hates Jessie. A model full of possibilities... http://www.renderosity.com/viewed.ez?galleryid=936411 http://www.renderosity.com/viewed.ez?galleryid=924771 http://www.renderosity.com/viewed.ez?galleryid=937237 (heh. nudity tag, this time I remembered it) :D
CASETTE
Attached Link: http://s54.yousendit.com/d.aspx?id=13B1E0S7WV0U02TV4S6GNLN38A
Two more smooth morphs to save you postwork time.One smooths the nostril creases, one the tips of the upper lip:
You can download both morphs HERE:
You can also apply all three smooth morphs at once and re-safe it as a single morph, but I left them separate for more versatility. for example I only used smooth brows and nostrils with remcs "Provedance", but left the lip as is:
Get the smooth-brow morph HERE:
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2580510
stahlratte
Message edited on: 02/13/2006 05:31
