Animation F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
Characters, motion graphics, props, particles... everything that moves!
Enjoy , create and share :)
Remember to check the FAQ for useful information and resources.
Animation learning and resources:
11 Second Club: Monthly character animation competition.
Animation Mentor: Online school. Learn from the animation masters.
Rigging 101: Maya rigs and rigging tutorials.
AnimWatch: Showcasting the best of independent animation.
FlashKit: The best place to learn Flash.
Armaverse: Stop-motion armatures for animation.
60+ great Character Animator's sites: Get inspired.
I agree -- Cinepak is the best codec for .AVIs. But I get my best animations by rendering in sequential .BMPs. I rename them to .DIBs and pull them into Videdit (freeware) to make the .AVI, then output it using no compression. This makes a crystal clear .AVI. I haven't compared filesizes for that approach vs. straight rendering to an .AVI, but I suspect it's quite a bit larger. - Jim
I believe that it's the same as rendering it as an uncompressed avi except that you made more work for yourself. Of course, an uncompressed avi is huge and unweildy; that's why they invented compression! Sequential files are best for post processing in Painter since some avi's don't import too well into Painter. Also, if you screw up one frame too badly, you can replace it easily. Chris
Doh! (hand slaps forehead). I got so used to going up the slider to the Cinepak codec, I never thought to check down it for an uncompressed .avi option. Thanks! (the other reason I sometimes render to individual pix is that I have not yet discovered a way to change textures during an animation. Probably a slider bar I haven't looked at!!!) - Jim
I think I became able to export .mov files after I installed Quicktime 4. generally render out of 3D Studio or After Effects. If you use the Sorenson codec in the quicktime properies at 100%, it comes out almost exactly as smooth as Uncompressed .avis. But there is a littel problem that the .mov files I create don't run on anyone else's computer. I have tried others with as similar configurations as my own, but they just don't play. They work so great on mine. And they are usually smaller even then the Cinepak .avis. Anyone who can explain this problem will have m,y gratitude.
I'm currently rendering poser animations (PC) and I don't have the choice of QuickTime animation, only AVI. Have I installed it incorrectly. Does anyone have advice on AVI configuration for better quality? I currently render at 30 fps but the quality, although smooth enough, is quite grainy. Would QuickTime produce better quality than AVI? Any advice would be welcome.
