Ryan, I think that you answered your own question. If I read your question correctly, you are trying to port a 2D planar surface to Vue through AutoCAD. In AutoCAD, if for the surface to be planar, the only changes are to be in the (X,Y) plane. AutoCAD expects all Z elevations to be the same, like 'zero'. As soon as you try to import something that has a change in 'Z' value, it will fail unless you use a 3D polyline. Another conflict is that X,Y,Z relationship in VUE does not match the X,Y,Z relationship in AutoCAD. In AutoCAD, the 'Y' is the vertical while in VUE it is the 'Z' axis. But I am sure that you are aware of this. My suggestion is to make your 2D plane a 3D one. You can send me your DWG and I'll see what your problem is.
Hi Ryan,
The shape is represented in AutoCAD as a SPLINE. It will not import just into VUE, but will not import into AMAPI nor HEXAGON. That leads me to suspect that a spline is not a definable entity in the 3DS file format.
I suggest that you create a surface of that shape in MS, export that to AutoCAD and then to 3DS. That process has always worked for me.
Message edited on: 02/16/2006 15:16
Facetres is the variable for Acis solids in Autocad. Should be at least 2. If you have a closed spline that is planar, you can export it as a region.
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
-Ryan Spaulding
VueRealism.Com
