The likeness is almost indistinguishable. This has to be one of the finest celebrity morphs ive seen! Is that painted hair on your morph? I think if you found a hair model just a bit thicker/fuller and a bit longer in the back you WOULD have an indistinguishable 3D clone :) Excellent, excellent job!
Most Excellently Done!
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Mostly there, not quite: * Eyes are too far apart * Nose isn't wide enough (mostly the bridge) * Lips aren't full enough (mostly not sticking out enough) * Chin should be more square The eyes are the wrong color and the hair is too small, but those things are obviously there as placeholders anyway :) Great likeness thus far.
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD
7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
You did that with only the DAZ morphs? Wow! A few small things you might still want to try: make the upper lip a little thinner, the face slightly longer und the nostrils higher. I seem to remember there's a DAZ morph for the latter, but I might confuse it with some other morph set. :-) I think everything else would be far beyond the reach of the DAZ morphs. Again, phantastic work! I'm sure once you make this available, we will see lots of Enterprise pictures in the galleries.
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
