Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
I have all the DCG plugins. I bought them as I needed them. Some I use more than others. I rarely do any cel rendering. I use Anything Goos a lot because it makes Carrara's shader capabilites an insanely better tool.
I recently picked up Anything Goos, but I'm still to where I feel comfortable using it. Like anything, the moe you play around with it... Still, by far my fav. DCG plup is Anything Grows. Luv it. Shonner, you posted some excellent renders with Toon Pro - the Jetson's. How did you apply it to all elements in scene? One by one? I picked up Vector style and I like the look, but want to post as jpegs for still images I can edit in Photoshop. Will ToonPro give the same vector look? Thanks R
Never Give Up!
Attached Link: http://www.shonner.com/drone1.swf
I didn't do The Jetson's. But I used to have Drone renders in my gallery done with Toon! Pro. But I like VectorStyle 2 better for some reason. See http://www.shonner.com/drone1.swf for a VectorStyle render. Resizing the window also resizes the render. You need Flash Player installed from Macromedia/Adobe.www.youtube.com/user/ShawnDriscollCG
Hello!i just want some feedback from users about this set of plugins ,especially toonpro and anything goos.I just tested toonpro demo sometime ...so so results from my side but maybe it is because i didn't take time to learn enough.Thanks to say what do you think about it?
Message edited on: 02/18/2006 10:26
