Sat, Jan 11, 1:41 AM CST
Subject: Turning off the "Help" Window in the Material Room
pookah69 ( ) posted Sun, 19 February 2006 at 11:38 AM ยท edited Sat, 11 January 2025 at 1:36 AM
In P5, every time I go to the material room, this window opens that gives advice on how to use it. How do I keep this from happening?
DCArt ( ) posted Sun, 19 February 2006 at 11:45 AM
Turn it off, and then go to the Edit > General Preferences command to launch the interface to the previous state. You'll have to turn off the help window in each room that you don't want to see it in.
pookah69 ( ) posted Mon, 20 February 2006 at 12:39 AM
Deecey, thanks for your answer, but it doesn't seem to be doing the trick. Perhaps I'm not interpreting your instructions correctly. After clicking the info window off, I open General Preferences, then what?
DCArt ( ) posted Mon, 20 February 2006 at 9:31 AM
Turn off the help windows that you want turned off. Open the General Preferences dialog, and check the option to launch the interface to the previous state. The next time you start Poser and go into the other room, the help window won't open.
