Sat, Nov 9, 8:36 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
Subject: P6 Lighting question
NolosQuinn ( ) posted Sun, 19 February 2006 at 4:58 PM ยท edited Fri, 26 July 2024 at 1:21 AM
I have a spotlight shining thru a window, the problem is that when I render the light also comes in under the wall, from the sides and the ceiling. The room is constructed like one in the real world, so no light should come thru, but it does. Any suggestions or tips would be helpful.
Thanks,
Djinn.
'I'm paying for this movie. I want guns'
operaguy ( ) posted Sun, 19 February 2006 at 5:06 PM
first suggestion is to close the angle on the spot so it only hits the window. One thing I do when aiming a spot is to turn the intensity up to 1000 so it is really bright, you can see the circumference really easily. Turn it back when done aiming. second, did you construct the building? or buy it? are the walls modular, if so you can move them to intersect each other. ::::: Opera :::::
Khai ( ) posted Sun, 19 February 2006 at 5:16 PM
try turning on Raytracing.. I've noticed that fixes Lightleaks 99% of the time. (You can have mesh intersection and lightleaks under the poser 4 renderengine and with non-raytraced lights..)
geep ( ) posted Sun, 19 February 2006 at 6:24 PM
... or ......................... you could use caulking. ;=]
(runs away quickly)
cheers,
dr geep ... :o]
edited 10/5/2019
NolosQuinn ( ) posted Mon, 20 February 2006 at 12:20 AM
I built the walls using poser props. They intersect but the light comes thru. Will try with raytrace on as Khai suggests.
Thanks all,
Djinn.
Robo2010 ( ) posted Mon, 20 February 2006 at 3:14 AM
lmao!! @ geep!.. :-)
stewer ( ) posted Mon, 20 February 2006 at 3:51 AM
Light leaking happens when the walls have no thickness but are just a thin polygon. Giving the walls real depth should cure it (like, building it from box primitives instead of plane primitives).
Acadia ( ) posted Mon, 20 February 2006 at 6:35 AM
Try these threads: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2517918 http://www.daz3d.com/support/tutorial/tutorial.php?id=906 http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2501525&Reply=2501937#14
