Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 9:32 am)
Huh ? Dunno what it is, but I'm taking it home right now ^^ Thank you very much :) Can't use the shader being on ProPack, but there was a nice freebie fox texture here in R'osity freestuff, and deer/furry package for Aiko at PoserClub.jp freebies. Hope this info helps P4/PP/D|S users who would like to play with her too :-)
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
So these are the things you do with your guinea pig scannings...
MWHA
Question: your texture has displacement or you added it only for your AIKOGUINEAPIG render? (her name is GUINNY, THE GUINEA FURRYTHING :P )
Message edited on: 02/22/2006 06:38
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
Awwww. a guineapig melts They're so CUTE! Yeah perhaps it IS a sort of guineapig.. I'm not sure.. it does make those little squealing noises wen..erhm.. uh.. oh nevermind....
Nah, it's not a guinea pig for sure. They have shorter and more roundes ears than this Aiko-something-lady ;) But can't deny it - she's cute, and real guinea pigs are even cuter :)
Hehe.. Actually.. the whole thing started because I wanted to make mouse/guineapig ears for Aiko. I had made some, by mistake, on another character (where I didn't save them because that wasn't what I wanted) .. and then it evolved into this critter :o) BTW.. the teeth.. Use Aiko's own Teeth Gone to move the teeth front/back and get rid of the teeth beside the "rabbit teeth" - ther eIS a morph that makes the two front teeth larger but it deosnt default make the rest go away. I didn't think of that until I was posing her for this shot :o)
I've done fur textures using P5/6 shaders, and I'd suggest the boundaries are a bit too sharp. I used the Clouds node for the colouring. If you wanted large blotches, such as the Spots node can give, it would be worth using Clouds for the colour inputs to give slight variations. I'll have a close look at this one and see what I can come up with.
There are several map-compatible texturesets which include a bump/displacement texture which will work better than plain noise. This also seems set a little strongly.
Yes, it does resemble a hard-used teddy-bear with a missing nose.
Also, more specular reflection from the nose would be good. This isn't a shader I would have started from, myself. I would have sorted out these basic differences, before adding the colour and fur texturing. But that's maybe just the way I work.
I've had a thought on how to combine the two texturemaps into one, taking advantage of the way that Poser can split a colour image into RGB components. The controlmaps would, I think, need to be a white-on-black, so that a set of three could be combined as RGB channels in the image editor, and the result split in Poser.
These are GREAT! I must admit that since this all just started as ..an attempt of a mouse ear morph.. I just more oe less slapped the texture on to give it SOME sort of texture... I love your second pic, the nose and inside of the ears did bother me. Your version is so much better!
1: The bump/displacement settings are at a lower value. Look at the eyebrows and the torso/arm boundary, where Ernyoka's material settings are still in use. This also gives better definition generally to the face.
2: Instead of noise, I've used a tiled texturemap.
3: The nose and ear control maps were combined into one. The different colouring was done with a Tile map. Scale values of 0.33 and 1 split the UV=space into three stripes, of two distinct colours. I didn't bother with the mortar width and colour, but the right settings could give you stripes of three different colours.
Remember that the head is scaled differently to the body in UV-space, by somewhere around 5:1.
Aww I LOVE that one, AntoniaTiger! So cute!
I've a feeling that the lip and nose colour, and maybe the eyes, don't quite go with the general tonality of the fur. Also, from the different angle, it looks as if I need to do a little more on the ears; the edges just look too thick at the top of the left ear. I want to check how much the mesh is stretched by the morph, and tweak the texturemap.
Wow! You're sure gettin g a lot out of my little "ear" Greatness! I guess I should try to do more of these anthros then...
Attached Link: My Homepage
... but it followed me home =o) And now it's available for free. A face morph and Poser 6 texture (texture is based on one of Ajax' free shaders) for Aiko 3. All new morph. On my homepage now, and soon through Free Stuff here as well :o) ~Have FunFREEBIES! | My Gallery | My Store | My FB | Tumblr |
