Mon, Feb 3, 8:55 AM CST
Subject: Ok Im a newb, I just got Poser 4 yesterday.
statix ( ) posted Tue, 27 March 2001 at 7:59 AM ยท edited Mon, 03 February 2025 at 8:41 AM
How in the hell do I put cloths on the model? Every time i pick a piece of clothing from the menu it makes the model disapear.
DeXTaH ( ) posted Tue, 27 March 2001 at 8:03 AM
I had the same problem. Just create a model... then choose clothing. to add the clothing click on the double-ticks. should be on the right side of your sreen under the clothing menu... Greets...
picnic ( ) posted Tue, 27 March 2001 at 8:30 AM
As he/she said. You will probably want to set preferences also, so you open with no model, choose one, then select the clothing by choosing the 2 checks. When the clothing appears in the window, make sure it is selected under the window, then go to figure/conform to and select figure 1 (most of the time--or whatever you wish the clothing to 'conform to'). You may need to tweak--that is make some parts of the body invisible--select the 'part', go to objects/properties (or double click on part) and uncheck 'visible'. I would suggest you start from page 1 in the manual--that was most helpful to me. Then--come back and ask questions for those things that you don't understand or that don't seem to be adequately explained in the manual. Have fun with it S. Diane
alcatraz ( ) posted Tue, 27 March 2001 at 9:32 AM
Make sure you are clicking on the double check mark to add clothing (in libarys)if you are clicking on the single one you are creating a new figure and the exsisiting model will disappear.
TRAVISB ( ) posted Wed, 28 March 2001 at 8:13 AM
Let me say welcome to hell if your like me you will have alreadys spent money and learned how to create your own models before you ever get the clothes to fit right good luck!
