thanks---i use these scripts all the time now, thanks SOOOO much.
lost in the wilderness
Poser 13, Poser11, Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine! Win11, I7, RTX 3060 12GB
Attached Link: http://www.netherworks-studios.com/nws-utility.htm
Updated two scripts at the Freebie Zone of our sitePoser File Re-Writer
This super-Script natively converts Poser 5 and 6 files into ProPack/P4 versions.
However, all options can be toggled on or off for a variety of uses:
Set Version number to 4.01, Remove Control Prop, Remove Dial Groups, Remove Shader Trees, Remove "Preview" Material, Convert Absolute to Relative Paths.
Remembers last directory used.
For end-users and merchants alike!
Update (2-24-06): Fixed version number setting routine
MAT Writer PLUS Pack
A Suite of 4 Python Scripts that allow you to easily write accurate MAT Files from within Poser.
Poser 5 and 6 users can write MATs with ShaderTree information or P4/PP Style MATs.
Poser ProPack users can write P4/PP Style MATs.
Includes GUI versions (PC only) or Numbered Sequence versions (PC or MAC).
Update (2-24-06) ShaderTree removal now works correctly.
