Fri, Nov 29, 8:32 PM CST
Subject: problem with applying texture to M3 genitals **NUDITY**
blonderella ( ) posted Tue, 28 February 2006 at 11:56 AM · edited Fri, 29 November 2024 at 5:48 PM
I have been trying to troubleshoot this problem for a couple of hours now and have tried everything I know...which I admit isn't a lot! I am trying to apply a texture in the material room to M3's genitals, and it works on the skin-torso but not on the foreskin...for some reason, the foreskin part remains white, as if there is no texture applied...I used shader spider to apply the texture to M3's main body, and tried using it for the genitals and when that didn't work I also tried to apply the genital texture by hand, but that also didn't work...I checked under the "figures" menu and genitals IS checked off, both on M3 and the penis figure itself...
I may be doing something wrong, or maybe there's a bug in P6?? any help appreciated! blushes and posts the pics Karen
Message edited on: 02/28/2006 11:58
Say what you mean and mean what you say.
blonderella ( ) posted Tue, 28 February 2006 at 11:59 AM
a closer up example
Ghostofmacbeth ( ) posted Tue, 28 February 2006 at 12:13 PM
I am not sure what texture you are working with but it is quie possible that the foreskin doesn't have a texture map on the texture set you are using. That would be my guess.
kathym ( ) posted Tue, 28 February 2006 at 12:16 PM
I haven't had any problems with texturing "equipment". Since the genitals are a seperate figure all to themselves, have you tried: Selecting Figure 2 (genitals) and making sure Body is selected and not body parts before you apply the texture from your menu? Every once in a while if i dont have "body" selected, I'll get a strange result.
Just enjoying the Vue. :0)
TrekkieGrrrl ( ) posted Tue, 28 February 2006 at 1:45 PM · edited Tue, 28 February 2006 at 1:46 PM
I'll go with Ghostofmacbeth's explanation. Since we can't see the whole of the texture on your screenshots.. IS there a foreskin texture present? It should be somewhere at the lower right corner of the map...
Message edited on: 02/28/2006 13:46
blonderella ( ) posted Tue, 28 February 2006 at 1:59 PM
is there a template somewhere for the genitals?? thanks! :D Karen
blonderella ( ) posted Tue, 28 February 2006 at 2:02 PM · edited Tue, 28 February 2006 at 2:02 PM
okay, I found the template and I see what you mean!! no, the texture didn't have the foreskin texture located in the lower right corner...thanks everyone for helping me straighten this out! :D (M3 thanks you too!!!!) hehehe
Message edited on: 02/28/2006 14:02
LostinSpaceman ( ) posted Tue, 28 February 2006 at 3:30 PM · edited Tue, 28 February 2006 at 3:31 PM
OUCHIE! Glad yo solved that problem before I ran into it!
Message edited on: 02/28/2006 15:31
blonderella ( ) posted Tue, 28 February 2006 at 6:28 PM
L something musta scared it awful bad...the blood's all drained from its...face ;P
