Mon, Feb 10, 6:51 AM CST
Subject: Miki ..!
thewishmaster ( ) posted Thu, 02 March 2006 at 10:46 AM ยท edited Thu, 06 February 2025 at 11:44 PM
Any one knows if Miki can be used in poser 4 ore is it only p6 ?
Rendergirls
Little_Dragon ( ) posted Thu, 02 March 2006 at 11:15 AM
Other than P5/P6 specific features, like advanced shader materials or the Face Room, she should be compatible with P4. Depending upon how she's packaged, you might need to manually uncompress some Poser files or convert PMD morphs, but it's do-able with third-party utilities by Cage, kuroyume0161, and Dimension3D. Accessories that utilise dynamic cloth or hair won't work properly in P4, of course. And you'd need to manually convert bump maps to P4's BUM format, but you're probably accustomed to that by now.
thewishmaster ( ) posted Thu, 02 March 2006 at 11:20 AM
Oki thanks :)
Rendergirls
Jules53757 ( ) posted Thu, 02 March 2006 at 11:58 AM
In general she would work in P4 - P5, but only to a limited extend. You CAN NOT use the morphs. They are included in a PMD file. This is a P6 only feature.
Ulli
Lawndart ( ) posted Thu, 02 March 2006 at 12:07 PM
You can turn off the option to save morphs seperately in P6 and then save the figure to the library. That will force the morphs to save internally in the figure. Then that newly saved figure will work in Poser 4 or 5 with the morphs intact.
Little_Dragon ( ) posted Thu, 02 March 2006 at 4:15 PM
That's why I mentioned kuroyume0161. He has a utility in Free Stuff which will convert PMD files to internal morphs, without the need for P6.
Lawndart ( ) posted Thu, 02 March 2006 at 4:46 PM
Hey nice! I didn't process that info correctly as I was reading it. :) Thanks LD
