Wed, Dec 25, 6:55 PM CST
Forum Moderators: Staff
Subject: Distribution of Jessi Morphs?
ExprssnImg ( ) posted Fri, 03 March 2006 at 10:21 AM · edited Wed, 25 December 2024 at 6:37 PM
I'm curious how to distribute morphs for Jessi. Cr2 distributing is illegal isn't it? V3 had geometry to copy to an INJ file but Jessi doesn't. Anybody know how this is done?
svdl ( ) posted Fri, 03 March 2006 at 11:02 AM
Attached Link: http://www.nerd3d.com
It's easiest to distribute Jessi morphs in .PMD format. Nerd3D has a tutorial on how to use those .PMD files on his site.
My gallery   My freestuff
ExprssnImg ( ) posted Fri, 03 March 2006 at 11:37 AM
Much appreciated man! I'll look into it.
ExprssnImg ( ) posted Fri, 03 March 2006 at 5:18 PM
It was quite simple too. The thing is. All the morphs and a FBM was made then saved to library. Then that PMD was there too. When I did the simple inj pointing to the PMD the dials were all turned off. So I did his secondary thingy. I had to make a pz2, 2 of them actually, One to point at the second pz2, then to the pmd, so the menu will contain an extra file that doesn't do anything but help the file function. The 2nd pz2 is like the old ones basically turning everything on. But I couldn't use it by itself, or at least I couldn't figure out how. Even with targeting the pmd for the morph data along with the necessary pz2info. Confused?
svdl ( ) posted Fri, 03 March 2006 at 6:08 PM
Nope, not confused. That's the way PMDs work. The morph data themselves are embedded in the PMD, and you need a .pz2 to load it and apply the settings.
ExprssnImg ( ) posted Fri, 03 March 2006 at 7:17 PM
But you said A pz2. I have 2 of them. The one that activates all the embedded info in the pmd. And another pz2 to turn on that pz2. It's not supposed to go down like that is it?
