Fri, Jan 24, 11:11 PM CST
Subject: "Out of memory" error message in Windows' Bryce4
dante ( ) posted Mon, 26 March 2001 at 12:49 PM · edited Thu, 09 January 2025 at 10:58 PM
Working on a complexe scene i get this msg when I try to import more obj. What is wrong? any help would be apreciated Thanks
firebreed ( ) posted Mon, 26 March 2001 at 3:02 PM
Hi. This usually means that you are low on "System RAM". How much RAM do you have right now?
RimRunner ( ) posted Mon, 26 March 2001 at 3:14 PM
There is another issue which can cause this error message. which version of Bryce 4 are you using ? Meta Creations or Corel .. and did you patch your Meta version with the Corel 4.1 update. I have Meta Creations version.. updated to the 4.1 patch from Meta Creations (still on www.brycetech.com) and could work with 3ds & cob file imports. Updated to Corel 4.1 (pretty much the same, just a new splash screen) and started getting this error message. :( If you have the Meta CD, uninstall .. get the update from Brycetech.. and update again. :) That fixed it for me.
The doctor says I have way too much blood in my caffeine system.
susan ( ) posted Wed, 28 March 2001 at 5:01 PM
Actually, I've gotten the same error message about being out of memory. I have bryce 4 with the corel patch. I have 384 megs ram. Unfortunately, I have a pc, not a mac, so I can't allocate memory. I'm using Windows 98 and am thinking of switching to windows 2000, which has a different memory management.
RimRunner ( ) posted Wed, 28 March 2001 at 5:17 PM
I hear that there are two versions of the Corel 4.x patch. One was flawed. I haven't tried the new corel update to see if this cures the error message or not.. the meta patch seems to do just fine :)
dante ( ) posted Wed, 28 March 2001 at 6:31 PM
Actually upon doing some experiments I noticed that this is irregular...for instance, I exported a figure from Poser that caused the msg upon importing it into Bryce...and another that didn't...actually a variation of the same figure...well, go figure...
