Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Here's an example. Say you wanted a mountain to go from sand, to green, to brown, to white as you moved up it's elevation. You could use the color gradient to do this. Here's I've used the Elevation shader to go from black to white along the Z axis of the mountain. Next I used the color gradient to transform that black to white gradient to sand, green, brown, and then white.
Does that help?
Regards,
Eric Winemiller
Digital Carvers Guild
Carrara Plug-ins
Eric Winemiller
Carrara and LightWave
plug-ins
Wow! I just want to say thank you to Mark and Eric, and everyone else for that matter who post such informative and thoughtful responses to questions. I learn so much from this forum. Find myself visiting it every day to see what has been posted. I always hope new images are posted - since I like to see what other people are working on, but posts like this are valuable in the idea and technical sort of way. Again, thanks. Good day.
Never Give Up!
I've read the manual. I've read the FAQ on Eovia's site. And I still don't understand the color gradient shader. I would have thought that a shader called Color Gradient would be used to make a color gradient, but apparently not. Eovia says it's "used in conjunction with another shader to produce a less rigid transition from one color to another." That sounds like a greyscale gradient. Can it also be used to make a color gradient?
