Wed, Jan 8, 12:51 AM CST
Subject: Putting morphs from Aiko 3 to her Ultra Catsuit from DAZ?
YngPhoenix ( ) posted Mon, 13 March 2006 at 1:59 AM · edited Mon, 06 January 2025 at 9:23 PM
As I had mentioned in my reply to the post: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2614093 I'm trying to find a way of putting the AikoGuy morphs for Aiko 3 into the Ultra Catsuit from DAZ. Anyone have any thoughts about how to do this? Just to mention it but I'm not familiar with Wardrobe Wizard and such. I'm also using Poser 5.
svdl ( ) posted Mon, 13 March 2006 at 4:06 AM
Attached Link: http://svdlinden.xs4all.nl/poserstuff/downloads/morphfromobj.zip
Yes, it can be done. Step #1: load Aiko and set her in ZERO pose. No morph set. Step #2: import the geometry of the Ultra CatSuit from the :runtime:geometries:DAZ folder (it's in a subfolder somewhere) Step #3: go to frame 20, apply the AikoGuy morph to Aiko at value 1 Step #4: go to the Cloth room, make a new cloth simulation, clothify the catsuit object and have it collide with Aiko. Assign ALL vertices to the constrained group. Step #5: calculate the simulation Step #6: export the catsuit OBJ at frame 30 as .OBJ. Check the options for body part names and existing group names. Step #7: reimport the OBJ Step #8: fire up the grouping tool with your reimported .OBJ selected and hit "Spawn Props" Step #9: load the Ultra Catsuit. Delete Aiko from your scene. Step #10: Edit my MorphFromOBJ python script (on line 5 or so you'll find the code: morphName="MyMorph". Change the text "MyMorph" into "Aiko Guy" and save the script). Step #11: Run the MorphFromOBJ script. Done. Your Ultra Catsuit now has AikoGuy morphs. Good luck!
My gallery   My freestuff
Hanz ( ) posted Mon, 13 March 2006 at 10:53 AM
...and what is AikoGuy? I'm intrigued, as I'm looking for more add-ons for this incredible figure (A3).
YngPhoenix ( ) posted Mon, 13 March 2006 at 1:26 PM · edited Mon, 13 March 2006 at 1:28 PM
Thanks svdl I'm going to give that a try tonight. Hanz: AikoGuy is a set of morphs here in the Freestuff section that will change Aiko3 into a male example shown above.
Message edited on: 03/13/2006 13:28
Hanz ( ) posted Mon, 13 March 2006 at 2:23 PM
wow, that's a cool freebie! ...(running off to download it!)...
YngPhoenix ( ) posted Mon, 13 March 2006 at 9:28 PM
svdl: doesn't seem to work. It hangs when doing step 5. I wonder if it's due to the type of morphs Aiko3 Guy are as they don't even show up in the cr2 of a character saved with them? Or is it because they consist of two or more morphs applied to Aiko 3 to change her to a male? Any further help on this would be appreciated.:) Also the Ultra Catsuit for Aiko 3 is a complete suit wich includes the head, hands and feet, I don't know if that's causing the hangup with Poser 5 or not?
svdl ( ) posted Mon, 13 March 2006 at 9:33 PM
Hmm. I'll see what I can find out.
svdl ( ) posted Mon, 13 March 2006 at 9:51 PM
Step #5 doesn't seem to work, you're correct. I'm trying with the Aiko Fantasy wrap, and Poser 6 seems to hang on my machine. I'm going to try a few other routes.
