Sun, Jan 26, 12:22 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: Using render nodes....
Jconxtc ( ) posted Wed, 15 March 2006 at 3:10 PM · edited Sun, 26 January 2025 at 12:13 AM
anyone care to tell me how to set up a small render farm in carrara? (5 pro)
operaguy ( ) posted Wed, 15 March 2006 at 3:33 PM
you should probably state how many CPUs you have, whether any of them are dual core or dual processor, what the host computer hardware is and what sort of networking you have.
Patrick_210 ( ) posted Wed, 15 March 2006 at 4:43 PM
First load the render node software on the other machines in the network, you don't need to load it on the host machine. Make sure you also install any plugins on the networked machines also. If you are using XP, the networked nodes will probably connect to each other automatically. When it comes time to render, you must first save your file. Then open the render node software on each machine. Then set up a batch render and enable "network rendering" on the host machine and then press "launch".
bluetone ( ) posted Wed, 15 March 2006 at 8:51 PM
Sounds so easy.... I have yet to get it to work, but... I have been busy at work alot, and have multiple different OS's to deal with...
Boogeyman ( ) posted Thu, 16 March 2006 at 10:09 AM
Would one need to open the associated ports on antivirus/firewall software (i.e. XP's Windows Firewall) to allow the render nodes on the network to talk to each other? I ran into a proverbial wall while setting up my nodes... however, I used the default port range set by Eovia (5025, 5035, etc) which might have been part of the problem. Someone suggested I use a port range of 26000+.
Jconxtc ( ) posted Thu, 16 March 2006 at 12:57 PM
any links to setting up a home network? oh, and I'll be using two p4 2.4g, and a g5 quad core 2.4g...
Boogeyman ( ) posted Thu, 16 March 2006 at 1:10 PM
Try this: http://www.pcworld.com/howto/article/0,aid,68763,00.asp The article is somewhat generalized, though it should get you started. A quick search on google should yield a plethora of more how-to documents.
