Sat, Nov 23, 4:27 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: vegis-low poly count
spinners ( ) posted Thu, 16 March 2006 at 5:34 PM · edited Sat, 23 November 2024 at 2:35 PM
So far i've downloaded several sample of low polycount vegis (3ds format) and they've crashed my Carrara 5pro. the internal plant maker is too heavy for my needs (got a city to vegetate)....any suggestions?
ShawnDriscoll ( ) posted Thu, 16 March 2006 at 6:44 PM
Do you have a wireframe image of the plant that you can post here to see where the problem may be in the model?
bwtr ( ) posted Fri, 17 March 2006 at 12:22 AM
Try the free app "Plant Studio".
bwtr
spinners ( ) posted Fri, 17 March 2006 at 12:45 AM
Attached Link: http://www.loopix-project.com/models/con_plants.htm
where it says free sample www.loopix-project.com/models/con_plants.htm as a standalone within carrara it worked...placed in my city, it crashed. I replaced the .tga with a .png, but that didnt help
bwtr ( ) posted Fri, 17 March 2006 at 1:38 AM
http://toucan.web.infoseek.co.jp/3DCG/3ds/FlowerModelsE.html And try this for more trouble free FREE stuff.
bwtr
bwtr ( ) posted Fri, 17 March 2006 at 1:53 AM
I downloaded the freebee tree from loopix and installed into th Carrara browser via the 3ds version. I clicked the image file in the shader dropdown as save internally though just to play safe. Used in a couple of Carrara scenes with no problem.
bwtr
ShawnDriscoll ( ) posted Fri, 17 March 2006 at 2:28 AM
The OBJ import didn't map very well out of the box for me. The 3DS version looked a little better when rendered. Free models always need re-editing to make them work. That's why they're free. The lo-poly 3DS tree rendered here took awhile because it uses over-lapping transparency planes (that light goes through) with tree images applied to them. Carrara trees render much quicker and look much better. But they are hi-poly. Which makes me think that your scene is crashing Carrara, not the free lo-poly tree.
