Fri, Jan 31, 1:48 AM CST
Subject: Does HyperVue support Resume render?
viche12345 ( ) posted Wed, 22 March 2006 at 2:51 PM · edited Thu, 30 January 2025 at 10:43 PM
Hello all, I want to render an animation with 480x270 frames. I played with Hypervue and Rendercow last night and discovered that this tool cut my render time enormously. However, 25 hours is still a very long time. I noticed Vue supported a function called "Resume Render". Is this supported in network rendering? Thanks.
RyanSpaulding ( ) posted Wed, 22 March 2006 at 3:38 PM
No, but when you abort your render, it asks you if you want to save all the frames already rendered. You then just have to render out a sequence next time you render...tell it to start at a specific frame and end at one.
-Ryan Spaulding
 VueRealism.Com
viche12345 ( ) posted Wed, 22 March 2006 at 6:41 PM
I see. However, I have to create a new file every time I resume the network render, or Vue will replace the original file. If this is correct, I will use Adobe Premiere or some other video editing application to assemble all the rendered frames. Thanks for the help RyanSpaulding.
