Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
If you have PhotoShop and ImageReady. Once you have all your frames made and saved to its own folder...(say in my pictures) go to File/ Edit in ImageReady Once ImageReady opens, go to.. File/Import...folder as frames (go to where you put the folder) Select it and hit ok You have to set the duration of each frame to get the desired animation.
I created this animation with four shots and changing the shutter speed.....=) sorry for the movement, I was hand holding the camera.
Message edited on: 03/26/2006 10:29
