To rescale the hand what you have to do, or at least one way to do it, is create a magnet on the hand itself. You then go through the properties thing and add element to deform. It is a pain but you have to add each of the parts of the hand . When done you can scale the magnet and all and you should get bigger hands. You also have to watch the zone some. Hope that helps.
scale all the hand parts down to the size you think would be correct start with the base of the hand, change the "taper" on the forearm to match the hand size if need be. some parts might become deformed in which case you may want to turn off the "bend" to that part (you can find that under object properties)
