Tue, Feb 4, 8:41 AM CST
Subject: Problems with zip files
jpemuk ( ) posted Wed, 29 March 2006 at 12:14 PM ยท edited Fri, 17 January 2025 at 12:20 PM
I have been working on some expression files and wanted to zip them up (using winzip 10). I am using the winzip wizard and all files do zip correctly. However when I come to install them using the Poser 6 'Install from zip Archive' from the 'Content Paradise' room. I get an error message stating that the exact path is missing. I am using (RuntimelibrariesFace) as a path followed by the folder I am placing the expressions in. The png graphic files don't install and I get the shrugging figure for the graphics instead. Any Idea's where I am going wrong (or how to rectify the problem)?
ratscloset ( ) posted Wed, 29 March 2006 at 12:20 PM
You need to build the Path in a Runtime Folder on your Root Directory (C:Runtime) Then you need to check the box for Save Full Path Info. (10 might have improved this, but this should still work. I still use 8.)
ratscloset
aka John
nruddock ( ) posted Wed, 29 March 2006 at 12:20 PM
The way you doing it at the moment is OK for unpacking with WinZip or similar, and is how just about everybody expects things to be packaged.
To be unpacked by the "Content Paradise" Room, you need an extra directory level above Runtime.
This is how the CP zips are organised (much to most peoples annoyance).
jpemuk ( ) posted Wed, 29 March 2006 at 12:23 PM
Cheers guys, that response was lightning fast.
