If you have it as a single obj you can edit the UV's in Carrara by hand...pull them out along the top and bottom where they are piling up. It's a pain, but... Can also wait for Hexagon 2 to ship, as it has both seam tools and a "relax" function that should make fixing a UV map much easier. I dunno about the whole assemblage thing. I just tend to work on a vertex object and weld parts in. Is more wrangling of vertices, tho (probably why I get so little finished).
Relax is a needed uv tool. You might also try blenders new UV tool, don't know if it has relax.I have only played abit w/ it, but it has alot there. I am definitely hoping the UV in hex is more usable because it would really help to do it in there.Of course, I can say that because I don't model in Carrara :)UV is so essential and kinda annoying so good tools are important.
No need to think outside the box....
Just make it
invisible.
love it... awesome models.... great render and pov Christina
Christina -- "Love me but don't tell me so" Lilly
Bart
My Art
![file_335059.jpg](https://live.cdn.renderosity.com/forum/threads/2624403/file_335059.jpg)
I've been working on a new model for a fish. Instead of one complete mesh for all parts, fins and body, I added fins to the object in vertex room, exported as .obj and imported again, .obj as one mesh. In the vertex room, it treats it as one object, although I have shader domains for each fin. But when I add bones, and get the little guy swimmin', the fins leave the body. I've played around with assigning different weights to the mesh/bones and that helps, but beyond that, I don't know what to do to keep it one mesh. Also a quick shader question. I don't like the stretched and faded spots on the body. It stretches out at the top. Would stretching the top back longer and painting with a larger brush/pencil/ tool in PS solve that problem? Asking before I try it, as I just spent three hours on it and i need a break. I hope Hex 2 with its new uv tools will solve this problem, but will Carrara bring the uv over and allow me to edit, add to it, etc.? Thanks RNever Give Up!
